Hey Everyone,
A few drafters in our office have been running into a fatal error when importing Sheet Layouts from a Master Template file we have set up for our construction drawing sheets. The error reads "FATAL ERROR: Unhandled Access Violation Reading 0x0090 Exception at A2DFEA6h". We reran the process after running cleanup on the drawing (Audit, Recover, Purge, -Purge), with the same result. Only difference between the two is the last Alphanumeric number changed to 539AFEA6h. We have run cleanup procedures on both the Template and the subject drawing, and the template works fine for others in the office. Dose anyone know a solution to prevent this from happening to other in the office. So far, between the two drafters that have had this issue, I see no common pattern other then importing the layout.
Thank you for your help, and have a great day.
