I exported parcel polygons from microstation DGN file into DWG file format.
I then opened the dwg file in Civil 3d, and used the 'create parcels from objects' button to convert all polygons to parcels. I deleted all irrelevant layers and objects.
I exported the file to IMX, and tried to import as a data source in Infraworks, a 'Failed to import data' window popped up.
I also tried to import the file as a Civil 3d DWG data source in Infraworks, but another 'Failed to import data' window popped up, saying 'IMX schema version is not supported'.
I am using Infraworks 2023.1 @2022 Autodesk, and Civil 3d 2023 @2022 Autodesk. So I think the version should be compatible.
How can I properly import parcels from Civil 3d to Infraworks?
