04:49 AM
Hi everyone.
I trying to extract some data and I can't figure out how.
I've got objects (mostly hatch atm, but I might want to extend this to solids as well) with a Work Breakdown Structure (WBS) code attached to them through a Property Set Definition. I've set up the code for the object in the extended data Property window.
I'm now trying to extract the WBS code from the hatches together with the area size.
The problem I run in to that through a normal data extraction I can't access the extended data.
Is there a work around?
