I have created several TIN volume surfaces and would like to extract the cut and fill information into a table so that it can be placed on to a drawing. Does anybody know of any automatic way of doing this rather than reviewing the surface properties and manually inputting figures into a table?
You can certainly create a table for each surface and place on the drawing but I don't think you can combine them into one table (there may be a way of using Parcel Volume Reports somehow but not sure...)
neilyj (No connection with Autodesk other than using the products in the real world)
It sounds like your surfaces are built form point/ feature lines and not corridors, yes?
You can still create sections, material list, volumes and in a dynamic table. Develop an alignment through your site ( I suggest a straight line) add sample lines and add all your surfaces ( I would suggest you make a composite of all your fg into a single surface), compute material and generate a material volume table. Of course you need to manually adjust pavement thickness, etc.
Joe Bouza
Gee I didn't know about that. Thanks
Joe Bouza
What goes around comes around I'd give you a check mark but the OP needs to dot that.
Please select "accept solution" so other readers may be aware of your solution
Joe Bouza
