Extract surface from Polyface Mesh
Hi there!
The purpose of this question is about how to extract surfaces from a polyface mesh.
My problem is that the ballast model of the project consists of several polyface meshes and I would like to get the bottom surface of the ballast bed, or the edges, at least. I would like to redefine the TIN surface of the existing ground from Infraworks. It could be done manually, however, the model is very large and complex so it is a very tedious and time-consuming task.
Do you know a possible solution for this problem? I have tried to convert it to a mesh and then either convert to a single surface, 3d solids or a NURBS surface, which did not work out because it only enables me to delete triangle by triangle.
Thank you so much in advance for your attention.
Best regards,
Carlos Jiménez.
