expression that hides link grades that are -50% and +50% and show the rest of the top labels with text height of say 2mm
oliverkisera
Message 1 of 8
oliverkisera
Hello good people, I have set this link expression , IF({Link Grade}=0,0,0.002), in the settings tab, to hide link grades that are 0% and to show the rest of the remaining top links, Ive attached a pic showing some top links showing -50% and I want those to be hidden, Ive tried creating expression that I can combine with the above expression such that it hides grades of -50% and +50%, but displays the rest of the grades with text height of 2mm, in the pic Ive auploaded, theres -50% slope appearing next to -1:2 slope, which is controled by daylight link slope assigned in the corridor, Im terribly in need to hide this -50% slopes being displayed by the corridor top links, since I dont have the pkt files, this is my only hope, any suggestion of such an expression that can do for me this will be highly appreciated. Thanks in advance
Replies (7)
Message 2 of 8
oliverkisera
Ive tried using this expression, IF({Link Grade})=0.5,0,0.002), but its hiding all link labels including the top pave levels like -2.5%, and so on, I only need to hide -50% and +50% link labels
Message 3 of 8
essam-salah
IF( (ABS({Link Grade}) > 0.4999) & (ABS({Link Grade}) < 0.5001), 0, 0.1)
above is an expression for label text height not the label text composer.
Notes:
- 0.4999 and 0.5001 is the bound of 0.5 of course you can increase precision,
-  0.1 is the label text height, you change it with the value you want.
Message 4 of 8
essam-salah
this weird the expression you are using in common cases will not hide any thing if you're using it as label text height, the reason is grade=0.5 is rare since in computer floating point numbers like double/float,... usually has tiny extra fractions so 0.5 might be 0.4999999997 or smth like that. you need to use epsilon/precision value to compare
Message 5 of 8
oliverkisera
Great, and Thanks for helping know that some values wont be exactly -0.5, Ive used this and it has worked, now I have clean cross-section labels, Thanks a lot, here is the expression,
IF({Link Grade} <-0.498, 0, 0.002)
Message 6 of 8
essam-salah
glad it works
Message 7 of 8
oliverkisera
Hello, how can I modify this expression, to also hide links whose grades are 0%, Ive struggled with it and still not getting it right, any expression that would the magic will be highly appreciated., here is the expression,
IF( (ABS({Link Grade}) > 0.4999) & (ABS({Link Grade}) < 0.5001), 0, 0.3), IF({Link Grade} <-0.498, 0, 0.002)
Message 8 of 8
essam-salah
these are two if statements which will return two values separated by comma as wrote it, which is not a double valid value, so what you need to do is ORing the two if expressions in one if statement, anyway below is how to hide grades values: 0.5 or -0.5 or 0
IF(
((ABS({Link Grade}) > 0.4999) & (ABS({Link Grade}) < 0.5001)) |
(ABS({Link Grade}) < 0.0001),
0,
0.03)
