EXPORTKML shows a wrong scale
Message 1 of 10
When I try to export a group of polylines from Autocad Civil3D 2017 into a KML file the result its in a wrong scale (aproximately 1/3 of the correct scale). The point of origin (0,0) is in place and there is no rotation, the only problem is the scale. I attach two pics, acad1 shows the original drawing in C3D with the red layer scaled up by a factor of 3.28, acad2 shows the result in Google Earth Pro with the drawing scaled down and the red layer aproximately in the correct position PD: the attach button is not working, here are the links: Acad1: https://scontent-eze1-1.xx.fbcdn.net/v/t1.0-9/14718618_1516236115069531_579403818676989895_n.jpg?oh=... Acad2: https://scontent-eze1-1.xx.fbcdn.net/v/l/t1.0-9/14670884_1516236271736182_6937114104622289621_n.jpg?...
Replies (9)
Message 2 of 10
Jeff_M
Sounds like a metric/imperial conversion issue. Is your coordinate system set correctly?
Jeff_M, also a frequent Swamper
Message 3 of 10
Coordinate System was ok (UTM84-20S). But your answer makes my check the drawing properties (AECCEDITDRAWINGPROPERTIES) and the drawing units were set in feet instead of meters. Problem solved. Thank you!
Message 4 of 10
Genius.
That was the problem with me too.
Solved.
Thanks very much
Message 5 of 10
IanMcClain
I think I'm having a similar issue, but by a factor of 12 (kmz is at the correct insert, but too small). "Drawing Units & Zone" and  "Units" are both set to US Survey feet.
Ian McClain
Message 6 of 10
Pointdump
Hi Ian,
Can you post your drawing and KMZ?
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2027
Message 7 of 10
topknot
Did you ever find a solution for the factor of 12? everything I have is in US survey feet and I have the same issue.
Message 8 of 10
topknot
I change Insertion Units in DDUNITS to Feet (instead of US Survey Feet) and it fixed the problem. Weird.
Message 9 of 10
topknot
It still isn't right. My project coordinate basis NAD83 with an XY shift, no rotation or scale factor. MAPEXPORT brings it to the right location, but that doesn't bring hatching. Export KML from toolspace will bring hatching, but it's not in the right place. Setting DDUNITS to US surveyors feet is off by a factor of 12. Using feet, it is close, but it seems off in location, rotation and a slight scale factor. I think it should be US surveyors feet, but I can't figure out the factor of 12 problem.  The drawing is 1 unit = 1 foot. Thoughts?
Message 10 of 10
Bsmrutiranjan48
Community Visitor
Community Visitor
When ever I tried to export kml file of any polygon from autocad. In Kml, area increasing something it's not match with accurate area with autocad.
  • Can anyone answer me, it is for what?
