Exporting with IFC 4.3 issue - XREF is exported as a block and with distortion
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I am trying to export an IFC with the new IFC exporter extension to be able to generate IFC with classes from a Civil3D file and no just "IfcBuildingElementProxy" objects + the BasePoint function, everything looked fine until I exported a file with External References (XREF) with multiple elements with different layers and properties inside. Normally, in order to create with the old exporter a Central Model you just need to export a clean DWG file with all the XREF files inserted and with that you will create the different "IfcBuildingStorey" categories, I was surprised that I am not able to export different building elements as a single entity with the new exporter because the XREF files are treated as Blocks and not as a container of multiple elements.
For the example I create 3 dwg files, 2 of them (Spheres.dwg and Cones.dwg) will contain several solids, I XREF the 2 files into a 3rd file (CentralModel.dwg) and I will export this one with the 2 exporters [IFCEXPORT(Old), and IFCINFRAEXPORT(4.3Extension)], and to be fair I will do in IFC4 format.
The IFC exported are:
CentralModel_IFCEXPORT (Old exporter)
CentralModel_IFCINFRAEXPORT (New exporter)
I am using:
- Civil3D 2025.1
- I have the last update of the extension
- I am using the BasePoint near the objects
Do you know how to fix the distortion and how to make the XREF not a single element when we export with the new IFCINFRAEXPORT? @snoyola Could you help me figuring out how to fix it?
