Civil 3D Forum
Exporting Surfaces with their feature lines from the model corridor
6 REPLIES 6
cyberflow
412 Views, 6 Replies
Hi there,
I'm actually prepping LandXML surfaces for my pave1, pave2, etc for construction based on my corridor.
I was wondering if there's an option to export the feature lines with the XML and not only the triangles ?
It's pretty heavy work to do this workflow :
1) Export LandXML
2) Extract features from corridor
3) Explode them and copy paste in a new file so the construction team can have them.
I'd like to save some time and headaches 🙂
Anyone knows a options/solution for this ?
And, is there a possibility to do it by batch ?
Frank Freitas
CAE/CAD/BIM Coordinator & Support Specialist
LinkedIn
6 REPLIES 6
wfberry
in reply to: cyberflow
Why are you wanting to do XML and Feature Lines?
Bill
cwr-pae
You can extract polylines directly from you corridor with out the intermediate step of feature lines. To speed things a little you can data reference the corridor with a code set that only shows the feature lines you want to extract (top edge of lane, etc.). If you have to do this often create  template to dref the corridor into with the code set style as default and maybe other presets to make it as easy as possible.
cyberflow
in reply to: cwr-pae
Nice idea to optimise the work, il'l give it a try next time.
But i'm looking for a more automated solution
Frank Freitas
LinkedIn
cwr-pae
Can you write lsp routines? Autodesk believes in the customer doing the heavy lifting ;/
cyberflow
No pain, no gain !
That would be an idea 😉
Frank Freitas
LinkedIn
cyberflow
In inroada when you export a surface the feature follow
And when u import it in c3d it shows the feature line
Its impossible i cant so the same with c3d
Frank Freitas
LinkedIn
Rail Community
