exporting points as shape files?
GreeneSWCD
Message 1 of 13
GreeneSWCD
I had this process down before my last update, but now it's either broke, or the process has changed?  I have four survey points, they are in a .csv file.  I need to export those four points as a .shp file, but when I use mapexport, points, Civil 3d finds those four, but then filters out those four leaving me with an empty shapefile.  I have a coordinate system assigned to the drawing.
Here you can see how four objects are selected, but all four are filtered out:
What am I missing?
Replies (12)
Message 2 of 13
tcorey
The "Points" referred to on the dialog are AutoCAD Point entities, not Civil 3D COGO Points.
To move COGO Points into .shp, export to .sdf (Autodesk's proprietary Spatial Data Format) first. Then import the sdf file using MapImport. Be sure you capture Object Data. This will create AutoCAD Points. You can then MapExport to .shp.
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Platinum Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
Message 3 of 13
tcorey
Here's a video that takes you through the steps:
Tim Corey
Redding, CA
Message 4 of 13
GreeneSWCD
Thanks for that, but in my Data tab, I don't have "object data" to select, like I used to in 2016.
Message 5 of 13
Udo_Huebner
@GreeneSWCD  wrote:
...I have four survey points, they are in a .csv file.  I need to export those four points as a .shp file..
as @tcorey suggested you can use following steps with Civil 3D 2022 or older versions
1. ImportPoints > you get Civil CoGoPoints from coordinates in CSV Text file
2. ExportToSDF   > Export Civil Objects like CoGoPoints to SDF
3. Mapimport    >  a SDF file and get AutoCAD Points with attached Object Data from SDF
4. MapExport  > AutoCAD Points to Esri Shape file with Points
Two other options (if you are using Civil 3D 2020 or 2021):
a) Using CoGoPoint
2. Install and use Autodesk_SHP_Import_Export_Utility_2021
https://up.autodesk.com/2021/CIV3D/Autodesk_SHP_Import_Export_Utility_2021_ReleaseNotes.htm
b) using Blocks (works in AutoCAD MAp 3D as well)
1. MAPImport  > Filetype  ASCII Point File, you'll get Blocks named Map_Survey_Point
2. MAPExport > Shape file using previously imported Blocks named Map_Survey_Point
It is best to upload your CSV file so we can see possible extended data to consider.
Gruß Udo Hübner (CAD-Huebner)
Message 6 of 13
tcorey
I think you missed the step of exporting to .sdf and then importing the sdf into a new drawing, from where you MapExport to shp. During import of sdf, you set the data column. See in the video.
Tim Corey
Redding, CA
Message 7 of 13
GreeneSWCD
I've did this process countless times over the last several years, and I've never had to deal with making a .sdf file until now.  THe process, as you guys describe it above, works.  It's just an extra step compared to 2016 back to 2009.
Thanks guys!
Message 8 of 13
Kelly.Hafner
Has anyone tried the 'Export Cogo Points to SHP' under the Toolbox tab?  I thought this was leading to something good in relation to  working with points but found it exports the point elevations into an integer field so rounds to the nearest foot.    Tried that for making drainage nodes for a model and wondered why many slopes were flat.    Just wanted to point out a word of caution if you try that option and think is works as advertised.
Message 9 of 13
TerryDotson
If you were to consider third party add-ons, DotSoft's C3DTools contains a dedicated Point Shape Write (and companion Point Shape Read tool).  Simply select a point group and your choice of properties, which can be standard CogoPoint properties or Point UDP.
Message 10 of 13
TerryDotson
Yes, that is the case.  Not only is the elevation exported as an integer, the northing and easting is also.  Tip, you can drag/drop a .DBF file into Excel to see the data contained.
Message 11 of 13
Kelly.Hafner
Thanks for the heads up on Excel, had not tried that before.  I tried the same thing with the export features lines to SHP and got all integers for the numeric data fields.  Wow, I guess making something potentially very useful almost worthless is not new.   Maybe some joins and relates for a points exported csv file and the shapefile database might help with the end goal of useful data.  Am going to play around more with Excel, that might make this much simpler to sort out.  Thank you again for your feedback.
Message 12 of 13
Liesl_H
Thank you for this great little video. Very helpful!
Liesl
Message 13 of 13
Liesl_H
Exporting to csv out of the toolspace - thanks for that tip! I was opening the points table and then exporting from there. This is easier.
