exporting a surface from civil 3d 2017 to trimble
I try TrimbleLinkforAutoCADCivil3D2017 (1) and it's not working we are on a big job and we don't want to use carlson can you help me
Pointdump
Y,
Welcome to the Autodesk Forum.
I've never been able to get Trimble Link to do much of anything. Your best bet is to install the free version of Trimble Business Center HCE. Then you can export your C3D surface to TBC HCE and convert it to a TTM. From there you have lots of options to export not only the TTM Surface to data collectors, but you can also export the SVD and SVL files that Trimble Machine Control needs for GPS dozers and blades.
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2027
If you need to export the surface, Trimble will understand the triangles. (Other than surfaces, I know nothing about Trimble software)
Change the surface display, so it will show the triangle.  Click the surface and on the ribbon select "extract objects" select the triangle and contours if you wish.
These can then be used by Trimble to create a surface.
Hope that helps,
tcorey
Hi @Pointdump. I hope you don't mind my asking you a question on a three-years-ago thread. 😉
When you say "Then you can export your Civil 3D surface to TBC HCE..." what format are you exporting to? LandXML? DXF of the triangles?
Tim
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Platinum Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
Hi Tim,
If using Trimble Business Centre, simply export to a LandXML, drag, and drop.
