EXPORT USER DEFINED COORDENATES SYSTEM
Salahelsheh
Message 1 of 8
Salahelsheh
HOW CAN I EXPORT USER DEFINED COORDENATES SYSTEM (DOSE NOT HAVE CODE)?
TO BE IMPORTED AND USED IN OTHER PC's.
THANKS IN ADVANCE.
Replies (7)
Message 2 of 8
rl_jackson
You should be able to save the drawing with the CS and then the other person opening the file with be informed of the new CS and asked if they want to save it to their library.
Now, @Pointdump  and myself ran into an issue with that can be found here:
 Re: Inserting Point Cloud into Custom Projection Drawing causes Fatal Error - Autodesk Community - C...
Rick Jackson
Survey CAD Technician VI
Message 3 of 8
Pointdump
Hi Salah,
More information please on what you have. Can you post your drawing?
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2025
Message 4 of 8
Salahelsheh
I WANT TO EXPORT USER DEFINED COORDINATES SYSTEM AS XML, SO OTHER COLLEAGUES CAN IMPORT IT AND USE IT
WHEN I USE MAPCSLIBRARYEXPORT, IT ASK FOR CODE
Message 5 of 8
ChicagoLooper
@Salahelsheh
<<...SO OTHER COLLIGUES CAN IMPORT IT AND USE IT...>>
What's the program the other colleagues area using?
AutoCAD? Arc Pro? Something else?
Chicagolooper
Message 6 of 8
Salahelsheh
AUTOCAD CIVIL 3D
Message 7 of 8
rl_jackson
Set a drawing to your new system, save the file and then have the other users open that drawing. It will request to add the CS to the library, just as I stated in my post #2
Rick Jackson
Message 8 of 8
Salahelsheh
Many thanks, gents
appreciated
