Export to Shapefiles from AutoCAD objects
Message 1 of 8
I wanted to export some autocad polylines objects to Esri Shape files. In the export dialog box, Selection tab: I selected "Line" and select layers that i want to export. After going thru three tab in this dialog box, i still have the below error! No entity to export. Can anyone please tell me what i did wrong? Thank you!
Replies (7)
Message 2 of 8
rl_jackson
I believe they must be polylines to export to SHP
Rick Jackson
Survey CAD Technician VI
Message 3 of 8
ToddRogers-WPM
If they are polylines, you must select Polygons instead of Lines.
Todd Rogers
Civil Administration at Walter P Moore
Message 4 of 8
Pointdump
Seattle,
Please post your drawing. I just tested it and using 2016 I was able to export both lines and polylines as "line".
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2025
Message 5 of 8
I figured out!
Thank you Everyone!
Seattle
Message 6 of 8
I thought i did, but i didn't! The Shape file is just empty!
I have attached the file here.
Message 7 of 8
If you have sucessful, please show me step by step. I am very new with this export.
Thanks much,
Seattle
Message 8 of 8
Pointdump
Seattle,
Quick and dirty, here's a Screencast. There are LOTS of fine points in exporting a Shapefile, but we'll save those for another day. After you export to shp, check the file size. I got 397 KB. If you MAPIMPORT it back into a drawing you'll see that it has some "parts" around the origin, which makes it look like there's nothing there. But there is.
Dave Stoll
Las Vegas, Nevada
