Hi all
I have problem when i export to auto cad
contour, Line corridor not show
Hi all
Since the surface is an object along with other things you may need to "save as" and do an explode. For the surface you could always extract the contours from the surface which would make them just normal polylines at the contour interval.
Rick Jackson
Survey CAD Technician VI
I have seen similar article on another forum with a solution check out this.
Also i have written here with all old school method fixes and actual what i found on Autodesk Troubleshooting as well.
Hopefully this may fix your issue. if not let me know i will try to install 2019 and i will give a try.
Neil
Founder Director | Neil Engineering Consultancy
Certified Civil 3d Professional | (Old) YouTube | (New) YouTube
is not work
Unfortunately i am not able to update my civil 3d to 2019.2.
Inserting as block, Wblock is not working. X-Ref and Bind/Insert is not working.
So the best solution is X-Ref your Civil 3D model drawing in to new drawing and export that new drawing to CAD it will work i tried and also attached the same.
Let me know if this dosn't works for you.
Note: i have created different style and layers for both surface so that you can easily play with the same.
How ever i will keep you update once i have updated my Civil 3D to 2019.2 version.
Neil
