Civil 3D Forum
Export Surfaces point TO CSV
7 REPLIES 7
Message 1 of 8
3149 Views, 7 Replies
Dear sir
My surface was created as per point groups data ,and this suface had been edited by delete suface point.
So i want to Export Surface points TO CSV, but points number still same as point groups data .
actually csv surface points should be deducted.
How to get correctly points data as surface.
Thank you sir.
7 REPLIES 7
Message 2 of 8
Civil3DReminders
Deleting the point from the surface doesn't affect the points. You'd have to delete the points from the drawing or remove them from the point group. If you don't need the point descriptions you could use this method: http://civilcommunity.autodesk.com/blogs/blog/6/blogpost/10511/ or this: http://blog.civil3dreminders.com/2009/05/how-to-create-civil-3d-points-for-each.html
Message 3 of 8
BrianHailey
Set the surface to use a style that displays the surface points. Export the surface points from the surface. Convert the acad points created from the export process to c3d points. Export those points.
Brian Hailey
http://www.cad-1.com
http://www.AtYourDeskTraining.com
Brian J. Hailey, P.E.
GEI Consultants
My Civil 3D Blog
Message 4 of 8
I am curious to know the reason for wanting this. Just my nature!
Bill
Message 5 of 8
Thank you So much
Message 6 of 8
i need to make submission survey points data to owner project or consultant.
Firstly ,the surface has been checked by myself .
If surface is not properly shape or incorrect, so that surface should be rectify and
then i have to export points from that surface.
However, i used to get surface points same method in Autodesk Land Desktop(LDT) by Autodesk Land XML Report,
surface points could be exported as my requirement.
i wish you get my point. Edited by: natty112003 on Aug 10, 2009 6:20 AM
Message 7 of 8
thank you for answer.
Message 8 of 8
A quicker way is to create a surface report. Reports Manager> Surface>
Surface Points to CSV.
Harold
natty112003 wrote:
> Dear sir
> Thank you sir.
Rail Community
