Export Inroads survey data to Civil 3D
Good afternoon,
I'm looking for any insight on exporting survey data that was processed in Inroads and importing it into a Civil 3D Survey database. The short version of why I need to do this is: we completed a topo survey in Inroads/Microstation (per Louisiana DOTD standards) and our internal design team wants it in Civil 3D.
We are hoping to find a way to take the survey data we have processed and cleaned up and import it into a Civil 3d survey database so that it creates the figures in linestyles that our design team knows how to use.
Issue 1: We exported all the points from Inroads (right-click on the .fwd, export as text file, in PNEZDA format) which creates a csv. The points are not exported in the same order they are organized in the .fwd which when imported into a civil 3d survey data base, the survey figures are not drawing/connecting to the points in the order that they should. We have also tried running the geometry report which creates an xml of the same data, all survey points...which again are not in the correct order.
Issue 2: In InRoads, you can JPT a line up to three different points. The code would be formatted like such:
300 JPT 5001 5002 5003 (300 is a code, and 5001 5002 and 5003 are three different point numbers)
In Civil 3D, I know we have to remove the space between the JPT and the point number.....but is it possible to have it JPT to 3 points total and if so, what is the correct formatting?
If anyone has any experience taking a fully processed survey from inroads to civil 3d, I'd love to hear from you! I can also provide more details if needed. Thanks.
