Export extended data from COGO points to txt or csv file
Hi All!
I've a big list of cogo points with extended information data placed in a custom property set.
It's possible to export them to a txt or csv file including the extended data?
I saw some workflows with mapexport but when I select all the COGO points, generated file is empty.
Thank you all!
Jeew-m
Is it possible to upload a sample dwg.
Jeewana Meegahage
Design Engineer
Autodesk Civil 3D Tutorials
Facebook | YouTube | LinkedIn
Here you can find the information of the points I'd like to extract in a table to export in excel
Jeew-m
Does this help you?
Jeewana Meegahage
Design Engineer
samir_rezk
Hi @Anonymous
You can create a Civil 3D table with the properties to be exported and then use this app to export the table to excel!
Property sets do not show up automatically in the Table Style component editor, but you can type it in as:
<[PS:UES:UES_PiloteDiametro(CU)]>
Where
UES is your property set definition name and,
UES_PiloteDiametro is the property set “property” name
Once you type in the code as a value for each column you want to be tabulated along with any other Cogo properties you’d like to include; create a Civil 3D table of the points, then use the civil table export app to export the information to excel!
A Schedule table per video in message 3 will only tabulate Property Set Data but without any of the Cogo point properties such as point number or xyz information.
Hope this helps,
Samir Rezk
Technical Support Specialist
