Hello, everyone. I hope you are well.
I have a question that is as follows: I need to export Civil3D files to ACAD. However, when exporting, I lose some properties, such as the wipeout and those transitions between one viewport page and another. In a geometric project, Civil3D generates a margin between one sheet and another, I lose this configuration when I export to ACAD.
Could please recommend a way for me not to lose these settings?
At,
Desenhista de Projetos em BIM
Engenharia Loading...
• Civil 3d • Revit • Infraworks • Dynamo • Excel
Gabriel Rafael | LinkedIn
Hi @Gabrielrafaelns, please let us know which method you are currently using?
Without knowing exactly what you are looking for, I suggest the following:
AECOBJEXPLODE, then choose your options at the window that prompts
_EXPORTC3DDRAWING, configure your options
EXPORTTOAUTOCAD2000 Just hit the command and choose a directory path to save.
I hope any of these options gives you the results you are looking for.
Best regards!
I have already used several export methods. Including importing pdf to autocad hehe.
But unfortunately the results were not as expected.
I need the export to cad, the wipeouts remain (in these green circles) and I need these transitions (in these red circles) to also remain.
In other words, the “ACAD” needs to be 100% identical to the PDF.
At,
