Export a surface to a grid file
tfitzhardinge
Message 1 of 11
tfitzhardinge
Hi
I have created a tin surface and need to export the surface into one of the following formats:
- .xyz
- .xyzs
- .txt (either as a esri grid format or xyz format)
- .asc
- .12da
The reason I need to export this surface into one of those format is that I need to load the surface into XPSWMM for 2D hydraulic flood modelling.
I am using AutoCAD Civil 3D 2016, using the Australian Map Grid of Australia Zone 56 Coordinates in the drawing settings.
Replies (10)
Message 2 of 11
autoMick
A .xyz or .asc file is usually just an ASCII text file (i.e. the same as a .txt or a .csv) - so you just create a text file then change the file name extension later in windows explorer if needed. The XYZ format is equivalent to ENZ.
So:
- create a surface style that displays the surface vertices
- extract those points
- convert those points to COGO points
- export those points to a text file.
A quick screencast:
Cheers
- Mick
Civil3d user in Australia since 2012.
Message 3 of 11
tfitzhardinge
Hi Mike
Thanks for the suggestion. Unfortunately the points have to be arranged in a grid like format (refer attached image) with an elevation value at each grid point. I have a feeling that Civil 3D cannot create this type of file easily.
Message 4 of 11
Alfred.NESWADBA
in the propector your can right-click your surface, export to dem (use file type geo-tiff).
With QGIS you can then convert the geo-tiff to e.g. esri ascii-grid.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Message 5 of 11
autoMick
Yes, save as GeoTIFF, microDEM is another freeware program that can open a geotiff and export in the format you want as shown by @Pointdump http://forums.autodesk.com/t5/autocad-civil-3d-general/creation-of-dem-georeferenced-in-the-uk/m-p/6...
Cheers
- Mick
Message 6 of 11
TerryDotson
Beware of any operation involving DEMs in Civil3D.  From what I've seen, since USGS DEMs store the elevation in integers only (no decimal), Civil3D treats at least some DEM operations this way.  I haven't tested every operation and am not 100% sure, but verify you have not lost precision when you do anything with them.
If you were to consider third party software, take a look at the C3D Surface Tools on the Autodesk Apps Store.  It will write a precision ESRI Ascii Grid (and a lot more formats) directly from your Civil3D surface in a single quick process (no wasting time jumping through hoops).
Message 7 of 11
Hidden_Brain
This looks like the contents of a .ASC file. If you have access to ArcMap:
1. Export surface from C3D as landxml
2. Import landxml in ArcMap, landxml to tin
3. Convert tin to asc
This is the process I use to get C3D surface into InfoWorks ICM.
Message 8 of 11
Joe-Bouza
Just guessing but you'll probably want to star with a grid surface. I believe that is a choice while creating a surface. Second guess: create a grid surface and paste the tin surface into it then export
Joe Bouza
Message 9 of 11
phil.pritchardN7HPY
how do you do this, i have been trying for some time to get this working in qgis but i cant do the conversion in the latest version of qgis.
Message 10 of 11
Alfred.NESWADBA
please find this video showing the steps to convert DEM to TIFF:
- alfred -
Alfred NESWADBA
Message 11 of 11
vandenoosterkamp
I had to do the exact same task today. I placed a single cogopoint with z=100. Arrayed them 1x1m covering the entire surface. Then 'elevation to surface', dropped them on the surface. Quickselected the remaining cogopoints with z=100, erased those and then exported them to csv.
