Exist & Entry Junctions daylight
Automohan
Automohan
This is 2d drawing which is exported from MX Roads software, I have input 3d polyline with levels as Image shows & Create the surface below
Is that possible to generate daylight lines (Earth works / slope lines) by civil 3d
thanks
Automohan
Happy Christmas
"Save Energy"
Did you find this reply helpful? If so please use the Accept as Solution
chriscowgill7373
if you are in 2017 or above, you can convert those 3d polylines to featurelines, create an assembly of a daylight and apply it to the featurelines as a corridor.  You can also use grading objects to achieve the daylight line.  Personally I prefer the corridor method.
Christopher T. Cowgill, P.E.
Civil 3D Certified Professional
Civil 3D 2026 on Windows 11
Automohan
at present don't have civil 3d 2017 I have 2014 & I will install it & check!
thank
"Save Energy"
chriscowgill7373
https://knowledge.autodesk.com/support/autocad-civil-3d/getting-started/caas/CloudHelp/cloudhelp/201...
2017 Is not backwards compatible to 2014 so exercise caution.  You can still convert the 3d polyline to featureline and use grading objects to do what you are trying to accomplish in 2014. Above is a link to some tutorials to teach you how to use grading tools
