Estilos de alinhamentos e pontos não estão aparecendo na lista
jsbaioco
Observer Observer
jsbaioco
Observer
Observer
A versão em português do Civil 3D não está mostrando os estilos de alinhamentos e pontos COGO nas respectivas listas de estilos. Apesar de os estilos estarem corretamente aplicados a cada objeto, nas listas de estilos apenas consta o estilo padrão "Norma". Isso não acontece na versão em inglês, apenas na versão em português.
RobertoJJoaquin
Do you have install COUNTRY PACK ?
Leave a like! If you found this helpful.
If your query has been solved, mark it as a solution. This will help other people find it easily later.
¡Deja un like! Si te fue útil lo indicado.
Si tu Consulta ha sido solucionada, marca como solución' esto ayudara a otras personas a encontrarla fácilmente a Posterior.
jsbaioco
Observer
Observer
Hi @RobertoJJoaquin ! Thank you for the reply. I did not have the country pack for Brazil installed. However, I installed today and tested, still the same result. Point and alignment styles do not show on the list, although they are correctly applied for each object.
Pointdump
Hi Juliana,
Welcome to the Autodesk Forums.
Can you open the English version template with the Portuguese version? Can you import those styles from one drawing to another?
If not, then you'll need to re-create those Point Styles in the Portuguese version.
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2025
jsbaioco
Observer
Observer
Hello and thank you, @Pointdump.
I tried saving the drawing as a template in the English version and opening in the Portuguese version and it opens with all the styles correctly. Unfortunately, that does not solve my problem, as my client only works with the Portuguese version of Civil 3D and needs to be able to view the drawing correctly as is. I just can't understand why it works perfectly on the English version and not on the Portuguese version.
