Error while applying decision on Subassembly Composer
I am trying to create a costume subassembly using the Subassembly Composer program.
I need to use a repeated sequence with decision so I used a flowchart inside the main flowchart.
In the internal flowchart I use a decision tool regarding to one of my Yes/No parameter.
I get this error message which is unclear to me:
"No is ambiguous variable. VisualBasic identifiers are case-insensitive." (see attachment)
I tried many nothing, and nothing seemed to help. I also try to use the Side parameter and it's seems to have the same problem.
Further more when I'm applying the exact same decision in the main flowchart everything works fine.
Also I have another costume subassembly with internal flowchart with similar decision regarding a Yes/no parameter and It's also works fine.
Anyone encountered this problem? anyone knows how to solve it?
Dror
Jowennl
works good!
Thank you!
