Error Code
Error Code
dannygreen8LCDX
Observer Observer
Error Code
dannygreen8LCDX
Observer
Observer
I've just updated to Civil 3D but using it solely as 2D Autocad.
For every command I input, I get this error code and I don't know how to resolve it :
System.BadImageFormatException: Bad IL format.
at System.Reflection.Assembly.Load(Byte[] rawAssembly, Byte[] rawSymbolStore)
at Autodesk.AutoCAD.Ribbon.TabEvaluatorFactory.Load()
Any offer of support would be appreciated, thanks.
VincentSheehan
Have you tried to run a reset?
Vincent Sheehan
Sr. Civil Designer
Poly In 3D Blog
dannygreen8LCDX
Observer
Observer
Thanks, but how would i do that?
Please assume i know nothing for ease of explanation.
Thanks again.
VincentSheehan
Click the Start button on the taskbar then go to your software version. Autodesk Civil 3D 20XX. Click Reset Settings to Default.
Vincent Sheehan
Sr. Civil Designer
Poly In 3D Blog
dannygreen8LCDX
Observer
Observer
perfect, thanks. Thats worked.
john_chesterton
Did not work for me
AllenJessup
https://www.google.com/search?q=System.BadImageFormatException%3A+Bad+IL+format.+at+System.Reflectio...
Allen Jessup
CAD Manager - Designer
