Entering WGS84 Coordinates into C3D
03:01 PM
So I want to enter WGS geographic coordinates (lat/lon in decimal degrees) into Civil 3D... I use Map command adesetcrdsys... I choose LL84 as coordinate system... use _AeccCreatePointManual with 'LL option... C3D creates a point...
Now when I draw some lines connecting civil points created this way, and do PublishKML, lines in Google Earth are some 8000 metres off... Is setting LL84 as coordinate system right option? Or is it something wrong with Google Earth export? Thank you for your reply!
Link copied
