Elevation point in 3D view
ragnheidur.karadottir
Hi!
I am modeling a surface and doing it in 3D view, using featurline. In elevation editor tabel you kan change the elevation but i kan not se where the point is in the 3D view, the green triangel you see in 2D plan. Is it possiable to see that green triangel in 3D view?
Ragna
Go to your point group in the toolspace-> select your point and it should be highlighted. Or you could try to view it in objectviewer
awood
You need to go into the Point Style - Display Tab
Change the View direction to Model an then turn on the Point
HTH
AWood
AlmasSuljevic
Autodesk Support
Autodesk Support
Just for clarification (spoke to him) I think Ragnheidur talks about “points” such as green triangles in the elevation editor. I don’t think it is possible to see those green triangles as they are really not points but rather some kind of vertices markers where elevation points are. Those cannot be visible in 3D view and they are not considered as objects eligible for different display.
Even if you select the feature line and go to 3D Orbit they will not show as connected to the feature line. So this it is not possible to adjust style settings.
Almas Suljevic
Product Support Specialist
Autodesk Global Subscription and Support
Autodesk, Inc.
Please click on "Accept as Solution" if post helped you resolve the issue.
jmayo-EE
Is layer 0 on and thawed?
John Mayo
jmayo-EE
Sorry. PI glyphs show up at elev 0. Elevation Points only will show at correct elevation.
John Mayo
