Hi eneryone. I have managed to do the following marking for my profile
This i insert manually as a label (add label from Annotate tab), by selecting a point representing the lowest y axis elevation in my profile view.
Two things i would like to ask.
1st. This is not dynamic. If i change my y axis elevation range (e.g. if i make it 130m in my example) this will not update to the new minimum y elevation. Is there a way i could have this elevation automatically updated showing the minimum elevation in my profile view (lowest y axis elevation in profile view)?
2nd. Although i have not tried it yet, i assume that if i create plan and profile sheets (utilizing Plan and Production Tools), where the profile might be gapped automatically, then this elevation will not be automatically updated to the minimum elevation of each sheet. So, going a little bit further from the previous question, is there a way i have this elevation automatically updated showing the minimum elevation (lowest y axis elevation) in each sheet?
Thanks!
