becank wrote:
> I have an alignment label style for the centerline alignment set for
> the text size and ticks to be the correct size for a 20sc plan sheet.
> We often change scale from sheet to sheet (mostly to 10sc or 30sc).
> When I edit the alignment label style to increase/decrease the text
> and tick size, it locks up and if I click anywhere inside the window
> I get an Internal Error. This happens about 90%, but about 10% of
> the time it works.
> Any clue how to keep if from locking up, or suggestions on ho w to
> set it up differently?
becank,
Did the error submission dialog show up after the fatal error? If so,
please send in a report with details on what you were doing at the time.
I attempted to find any CERs with "becank" in them, but that turned up
empty. If you post any identifying information I can use to locate your
CER that would help. If you don't want to post it publicly, please send
me an email (use first.last@autodesk.com format).
Civil 3D version and service pack information is vital in diagnosing
these issues and known defects, so please post that in each message.
Thanks.
Himanshu Gohel. Civil 3D Team, Autodesk, Inc.
Autodesk Civil 3D Product Information: http://www.autodesk.com/civil3d
Civil Engineering Community Portal: http://civilcommunity.autodesk.com
