Civil 3D Forum
Edit sub-assemblies in the Corridor Modeling Catalog
2 REPLIES 2
627 Views, 2 Replies
I am using C3D 2013.
Is it possible to edit a sub-assembly in the Corridor Modeling Catalog (Imperial.NET) see attached image.
The company I work for has several users working off one network server. I would like to make a revision to one of the dimensions in the sub-assembly "UrbanCurbGutterGeneral" (the default gutter width is 16" I would like to make the default 18"). I'm assuming I need to change this in the Catalog so every users tool palette will be updated also.
Any help or practices are appreciated.
2 REPLIES 2
You may want to try editing the tool from the palette instead of the catalog.
Thanks for the reply:
I see you can edit sub-assemblies from the tool palette. The problem I have is the revisions are then only on my computer. My goal was to be able to edit the catalog so all other user also would have their tool palettes updated.
I did follow the autocad help steps but it did not change the other uses palettes.
Thanks again for the reply.
Rail Community
