>> but do not know where Civil 3D stores the linetypes/*.lin files of externally created drawings
At the moment a linetype is loaded it's definition is stored within the drawing-file and stays inside the drawing as long as it's not purged out. The only subelement of a linetype, a SHX (if a linetype is defined to use symbols) is a separate file that holds the geometry-definition of the symbol.
So the answer to "where Civil 3D stores the linetypes" is: in the drawing. It does not need a LIN-file any more to display the linetype correctly.
>> I want to edit linetypes
You can't edit linetypes within the DWG file. You have the option to create a new linetype in one of your LIN-files, and load that new definition. If your new linetype-definition has the same name as the existing one in the drawing you get asked if you want to replace it. Answer yes and you have redefined the existing linetype with your new one.
HTH, - alfred -
Alfred NESWADBA
www.ish-solutions.at ...
blog.ish-solutions.at ...
LinkedIn ...
CDay 2026------------------------------------------------------------------------------------
(not an Autodesk consultant)
