Civil 3D Forum
EDIT DRAWING SETTINGS ERROR (Potential Fix)
1 REPLY 1
443 Views, 1 Reply
Hello All,
I might have found the bug in the Drawing Settings. From my earlier post, the dialog box would try to open and would give an error "Enter a Number." If you remove location marker for Bing maps, then the error goes away. I just stumbled upon this "fix" this morning. I do not know if this will fix the problem. Hopefully if will.
Kris
1 REPLY 1
Hello All,
Thanks for the kudo, whoever you are! I think that it was undeserved. While removing the location maker for Bing maps did alleviate the error, it also changed the coordinate system for my state plane to no datum/no projection. This is problematic if you work is primarily done on State plane in tandem with GPS. No so much if you work on an assumed/ local coordinate system.
But low, I think have found the real culprit! Under the ambient settings tab, I had change the Rounding setting from round normal (default) to round up. We all know how well this over priced program rounds numbers, ha!!! As soon as I changed it back to the default setting, the world was once again a beautiful and love place to exist.
Hope this helps.
Kris
Rail Community
