I am trying to learn more about using the new Edit Corridor Transition. When I am picking the stations and setting parameters it is working as it should be. However, when I get to the end I cannot change the side that the transition is occurring on. It is always set on left and it is not allowing me to change that. I tried to go the opposite way but it is not letting me go in reverse stations.
Solved by VincentSheehan. Go to Solution.
You'll need to pick the other side/right side in order to adjust that side when creating a new transition set.
I have been trying to select that side, I'm not sure why it is not recognizing this. Select the right side when clicking to identify the stations?
I am using the basic lane assembly. when I clicked on the curb just to try, it did have the right in the dialogue box. I thought that this feature was supposed to be compatible with the basic lane assembly
It's compatible. Did you press the Apply button. Nothing updates until you do that.
