ecw file offset when ploting from layout
sinisa.jovanovic
sinisa.jovanovic
I noticed that when I create a pdf file that I plot from Layout, the attached ecw file is offset, while when I plot from Model, there is no offset. I also noticed that when adjusting the drawing or using the MVSETUP > Align > Rotate view function, this causes the above-mentioned offset of the attached ecw file. Has anyone had a similar problem?
paullimapa
Are you running Map3D or Civil3D?
Paul Li
IT Specialist
@The Office
sinisa.jovanovic
Im running Civil 3D 2023.
paullimapa
To get better feedback you may want to post here
https://forums.autodesk.com/t5/civil-3d-forum/bd-p/66
Paul Li
IT Specialist
@The Office
sinisa.jovanovic
Okay, I'll do it.
paullimapa
You are welcome…cheers!!!
Paul Li
IT Specialist
@The Office
