ECW-file not visible via Map Connect
I converted a GeoTIFF aerial image into an ECW-file using FME. But now I can only see the image in Autocad using the mapiinsert command, when I add the ECW-file using the map connect I only see the boundary if I select the image but the image itself stays black.
Any ideas what this can be?Map connectMap connectMapiinsertMapiinsert
Never mind, already found it. Had to change the transparancy in the Style Editor.
