@huynhphanson71
I had a .ecw v2 which had a transparency band but when toggling transparency on in C3D there were small pixels around the irregular clip of the Ortho that persisted to show around the edges. Most frustrating since this issue does “not” occur in ArcGIS Pro.
Anyway, I tried exporting from Geocompressor new versions of the .ecw with different backgrounds (white and black assigned as the transparency band), but no luck until I can across your tip about using an image clip. Problem solved.
I wonder if this issue would persist in the latest version 3 of .ecw, but sadly it still is “not” supported 😒 Knowing how popular UAS imagery is and all the documented issues around large size tif files in C3D, you would think Autodesk would recognize these compressed image formats as a real viable work-a-round. the solution is here in .ecw. 2.5GB drone image compressed to 80MB...no problem. All they have to do is support it!!
end rant /
Michael M. Carlson
Senior Civil Designer
CADD Manager
AutoCAD Civil 3D Infrastructure Design Professional
AutoCAD Design Professional
