Earthwork. xls import to excel with specific xml value.
hi,
In my hand came some very intresting file.
It's cut & fill  report.
I  would like to know,  how it is work ?
How i  Can import to EXCEL and everything will  be looking same?
I  found that i  must use developer kit in  excel  to import that .xml  file, but when i  try it's seems that something went wrong.
And how i  can  create my own style of earthwork.xls ?
I want to export just specific value that i  just need.
Tomasz_Piotrowski
Hi @Anonymous
yes, you have to add the Developer tab to your the ribbon. Then you will be able to import data, edit styles etc.
Here you will find a nice video about it:
Edit XML Earthwork Report in Microsoft Excel
Please check it and let me know if you need any assistance.
Tomasz Piotrowski
Product Owner/ QA Engineer - RSA Project
Tomasz_Piotrowski
And one thing more. The default location for the stylesheet that is used for this report is
C:\ProgramData\Autodesk\C3D <version>\enu\Data\Cut Fill Report\
The file name is CutFillReport.xsl.
Tomasz Piotrowski
