- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hello the Community.
I need an informed opinion.
I work on Autocad civil 3d 2024 which I master well, and I need to improve my skills in automating commands or creating commands that do not exist. I do not know much about programming so I started with Dynamo, but I admit that I am quite disappointed by the possibilities, but I do not know if it is due to my inexperience.
For example, I have not found a simple way/node allowing me to extract the coordinates of the vertices of a polyline, and each action seems very complex to me, even sometimes impossible. Sometimes we do not even know if the node in question exists? and in which package? For example I heard about the node Object.Geometry but I never found it!
Another example, I tried to make a script to export polylines in SHP with their elevation, which seems very simple, but even with the help of chatGPT I never find the appropriate nodes.
So I need your advice, should I persevere with Dynamo, or should I learn programming to make lisp, which now seem easier to me... I heard that Dynamo was very good with Revit, but less with Civil, is that true?
Thanks in advance for your feedback!
