Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
Civil 3D Forum
Dynamo Missing from Civil3D 2025
13 REPLIES 13
Message 1 of 14
NateSarles
1002 Views, 13 Replies
I have tried uninstalling and reinstalling 2025 but Dynamo does not appear in the 'Manage' tab of the ribbon. I have also checked the updates, plug-ins, and add-ons on the 'my products' page. Am I just too ambitious to think that the new Dynamo plug-in would be ready this soon after the initial release of 2025? Or is there a glitch causing it to be missing?
Is anyone else experiencing this?
C3D 2022
Experienced Civil Site Designer/Drafter
Windows 11, 64 GB RAM
13th Gen Intel(R) Core(TM) i7-13850HX
Labels (2)
13 REPLIES 13
Message 2 of 14
rkmcswain
in reply to: NateSarles
Have you seen this?
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Dynamo-extension-i...
Message 3 of 14
DarrenP
dynamo is part of 2025 its not a separate install
are you not seeing it here see screenshot below:
DarrenP
Message 4 of 14
NateSarles
in reply to: DarrenP
I am aware that it is intended to be part of the standard install. I do not see that, no. That is why I created this post.
C3D 2022
Message 5 of 14
rkmcswain
Did you by chance let it "migrate" your settings, or otherwise end up with a non-C3D 2025 menu file loaded?
Message 6 of 14
NateSarles
in reply to: rkmcswain
Yes, I had installed Civil3d after that update was put out so I assumed that I didn't need to download it, but just to be sure, I just checked...
C3D 2022
Message 7 of 14
NateSarles
I migrated my settings from 2024... But 2024 had Dynamo active...
C3D 2022
Message 8 of 14
NateSarles
Would it, by chance, be caused by me still having 2024 installed?
C3D 2022
Message 9 of 14
DarrenP
no i have 2024 &  2025 installed but i didn't transfer my setting from 2024
did you go through the link that was provided?
if so you will probably need to uninstall/reinstall 2025 if that didn't work
DarrenP
Message 10 of 14
rkmcswain
Can you reload the OOTB C3D.CUIX menu?
Message 11 of 14
NateSarles
OK! I was able to start Dynamo using the "AECCLAUNCHDYNAMO" command, but the panel is just missing from the ribbon. Can I reset JUST the .CUIX menu file without having to uninstall and reinstall?
C3D 2022
Message 12 of 14
Migration in Civil 3D is not supported, which is why there is no Migrate dialog when it first opens.  I thought there was a new version of Dynamo, which might be why your ribbon isnt loading correctly.  Within the CUI editor, you can right click on Civil and select to restore C3D.cuix.   This would in theory reset the cui without messing up your profile.  But, if you migrated, it might be best to start fresh with the reset settings to default.
Christopher T. Cowgill, P.E.
Civil 3D Certified Professional
Civil 3D 2022 on Windows 10
Message 13 of 14
NateSarles
@DarrenP @chriscowgill7373
I finally got around to giving a fresh install a chance and that did indeed fix it... Granted I was also having an issue with my parts list that required me to reinstall.
I guess manually setting up all my preferences is the best/only way to go...
C3D 2022
Message 14 of 14
it may be possible to automate a lot of it, depending on what it is that you use for your preferences.
I created a package bundle that I can load with each new release, and it brings in all of my settings.  I keep my own separate cuix file, so it isnt migrating anything from within the program, so the only thing it is doing is changing what is present in that version.  It could be worth a look.
Rail Community
