@Anonymous, thanks for your response. As indicated in my response to the other related thread, I have a feeling I can't achieve what I want through modelling dynamic volume surfaces alone.
For others reading this, I am trying to get the volume of sub-surface materials dynamically without using the Material Quantities command as this is painstakingly slow on long complex alignments, especially when multiple edits are being made. I just want to be able to review the totals for each material on the go while making edits to balance or generate material. The volumes dashboard is a great tool but I would like to be able to list the volumes in a table where I can then add formula to make calculations between them. I think that I could get around the whole thing if I am able to create dynamic links to a table showing the cut volume of the surfaces and then use formula to do what I need.
For example I could have three volume surfaces as below:
1 - Rock Cut (compare design surface to top of rock)
2 - Rock+Clay Cut (compare design surface to top of clay)
3 - Rock+Clay+Topsoil Cut (compare design surface to top of topsoil)
If these values were in a table I could then apply formula as below:
1 - Rock Volume = (Rock Cut)
2 - Clay Volume = (Rock+Clay Cut) - (Rock Cut)
3 - Topsoil Volume = (Rock+Clay+Topsoil Cut) - (Rock+Clay Cut)
As I alter my profile/alignment these values would then be automatically refreshed (maybe requiring a regen first).
I just need to figure out how to link to the cut values of volume surfaces...……………...
