Civil 3D Forum
dynamic layer in assembly
1 REPLY 1
270 Views, 1 Reply
I have pavement system with asphalt,base and subbase layers. in fill sections there are different fill materials. for example top 30 cm layer will be compacted 100% 75 cm below that layer with be 95% compacted and ...
I don't have this layers in cut part of sections. how can I get this volumes of different layers?
can I add a layer to assembly and want assembly to and this layer on fill part or assembly will consider all layers fully?
1 REPLY 1
KMercier_C3D
The ConditionalCutOrFill subassembly may help give you what you need. Here is more info
Kati Mercier, P.E. | LinkedIn | AutoCAD Civil 3D Certified Professional
Pronouns: She/Her
Co-author of "Mastering AutoCAD Civil 3D 2013"
AU2019 Speaker::: CES321590: Analyze and Revise Existing Subassembly Composer PKT Files for AutoCAD Civil 3D
AU2017 Speaker::: CI125544: Analyze and Devise in Subassembly Composer
AU2012 Speaker::: CI3001: Reverse Engineering with Subassembly Composer for AutoCAD Civil 3D
AU2011 Speaker::: CI4252: Create Subassemblies That Think Outside the Box With Subassembly Composer for AutoCAD® Civil 3D®
Tags (1)
Rail Community
