Announcements
Dynamic Corridor Feature Lines...
Jerry_Barnes
Jerry_Barnes
I created a dynamic corridor feature line in C3D 2015. I'm trying to target a curb return width and elevation to the feature line by selecting it from the Corridor Parameters dialog box. After selection (and the feature line is highlighted), I return to the dialog box but the feature line does not appear as being selected at all. I tried selecting it via the Layer route as well, but no dice.
Any ideas as to why I cannot target a dynamic feature line? Targeting alignments and profiles works completely fine.
jmayo-EE
If the fline originates from the same corridor you would be creating a circular reference.
John Mayo
Jerry_Barnes
Ahhhh......! Exactly. Thanks.
michaelrupp61
This can be done by using multiple baselines within the same corridor using codes in your template to separate the circular reference problem , please see my post,  I use a target baseline and code to create a target surface, and then create a grade surface that can obtain 'relative' dynamic elevations from the targeyt surface, all within one corridor.
