Due to scheduled maintenance, the Autodesk Community will be inaccessible from 10:00PM PDT on Oct 16th for approximately 1 hour. We appreciate your patience during this time.
Civil 3D Forum
DYNAMIC BLOCK ON THE LAYOUT
5 REPLIES 5
421 Views, 5 Replies
Hi!
I made a dynamic block that changes the name of the Engineer and the number of the crea among the registered options. I would like to know if there is a way to link this block in the stamp of all the layouts created so that if I change the option from João to Maria in one layout he will update the rest.
Tags (2)
Labels (1)
5 REPLIES 5
jae.kwon
What you want to do is create a Sheet Set, and either use the default properties there or create your own custom ones. Once you import a layout into a sheet set (import's probably the wrong word for it... more like create a link), you can use a field to look for the property stored in the sheet set. This will make that text dynamically update based on what value you put into the sheet set.
This is a good place to start as any I guess: https://knowledge.autodesk.com/support/autocad/learn-explore/caas/CloudHelp/cloudhelp/2016/ENU/AutoC...
I'm sure there are many Youtube videos on it as well.
Joe-Bouza
As @jae.kwon  said Sheet sets are really good for names and and dates and what not. IMHO stamps and logos are better handled with layer states.
You can chain actions together in the dyno but the stamp and the crea along with the consultant logos would all want to be together in one block. Probably increasing the number of viz states. lookups etc..
Once you get that all tied in a nice bundle, you use qselect to grab all the block on all the layouts by filtering entire drwing by block reference name, the change the viz state/ lookup in the properties palette. (record that macro)
or you can change the layer state. See what I mean.
Joe Bouza
in reply to: jae.kwon
Thank you!
in reply to: Joe-Bouza
Thank you so much, it helped me a lot!
Joe-Bouza
Happy to hear.
Good luck
Joe Bouza
Rail Community
