DXF file conversion
Dharshana.Gunarathna
DXF file conversion
I am trying to convert (Export) my civil 3d file to DXF file. When I try to open the file, the following window appear in the screen.
Could you explain why is it?
Dharshan
Replies (7)
Neilw_05
What method did you use to create the DXF? Did you use the Export to Autocad tool in the File menu? That tool will convert the C3D objects to plain ACAD objects based on the settings you choose. Simply doing a SAVEAS to DXF will not convert the C3D objects and the results will not be as desired.
Neil Wilson (a.k.a. neilw)
AEC Collection/C3D 2024, LDT 2004, Power Civil v8i SS1
WIN 10 64 PRO
http://www.sec-landmgt.com
Hi Neil,
I did export as DFX from C3D.
Also, I did try to export to DWG, then save it as dxf too.
Following error saw in command line,
Let me know if you need my file.
Thank you,
D
Neilw_05
I don't know why you are having issues based on your comments in the forum. The error message you show is related to PDF files. Does your dwg have pdf files attached? If so, try detaching then export to DXF.
That question leads to doing basic troubleshooting. Save your file to a temp file and start deleting objects and exporting to DXF. The idea is to incrementally eliminate all the possible objects that might cause problems. Start with a broad selection of objects and narrow it down as you find them.
WIN 10 64 PRO
Thaks Neile, I will update you soon.
D
rl_jackson
Also, as a prequel, I would do a save as of your drawing, explode everything, explode everything again and then export do a DXFOUT (same as the command your using in the menu). Like export to ACAD there are hiccups with sending things to DXF...
Rick Jackson
Survey CAD Technician VI
Hi Neil,
There was a pdf file. Once I detached it, the dxf export came out perfect.
Thank you,
Dharshana
Hi Rick,
Thank you,
Dharshana
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
