Hi
A few days ago i was working with a file and everything was working perfectly, not a single problem related to lag.
Suddenly, when i opened my file yesterday, it became really weird, the annotations are pixeld, when i pan civil 3d lags, when i PAN using the scroll button sometimes the COMMAND stands working even when i release the scroll button, and the use of memory coming from this file is almost 12x higher than a similar file.
I dont know what happened, or if i did something different that made this file to look weird, but there is something wrong with it. THIS IS HAPPENING ONLY IN THIS FILE SPECIFICALLY
Solutions that i tried: AUDIT (No errors found), RECOVER (Nothing changes), PURGE (Nothing changes), SELECTIONPREVIEW= 0, COMMANDPREVIEW = 0, REGEN COMMAND doesnt not work, REGENALL idem, and the COMMAND REGENAUTO is set to ON, DISABLING GRAPHIC PERFOMANCE (Nothing changes)
I cant attach the DWG here, but i can send it on a personal/private email if someone wants to help me out.
Appreciate any help
Obs: I attached three prints here, one from the annotation, the second one is when i PAN around the file, and the third is the use of memory from a similar file. The weird part about the second image is the behavior from the tiff images, before i could see them normally when i used the commando PAN, but now a few of them vanish,
Arthur
Civil 3D VERSION 2020
WINDOWS 10
