I have a drawing set up in a local coordinate zone. The CS code is: FillmoreMN-F. The Projection is: LM-MNDOT. The datum is: NAD83. The Units are U.S. Survey feet. I created a surface and want to import a dem of a quadrangle map (Washington, MN-24000) downloaded from the USGS Data-depot. The dtm is in UTM, NAD 27, Zone 15, Meter. When I input the CS code of the dem in the import dialog box and click ok the command appears to cancel, and the dem is not applied to the surface. I can get the dem to import if i don't use apply a cs code for the dem, but then it is not in the right place. When I apply the dem with no cs code and then try apply the cs code through the prospector window by right clicking the name of the dem and selecting 'properties', the cs code isn't applied.
I've dont this successfully in LDD 3 and LDD 2004.
