Dref corridor not working
Joe-Bouza
Mentor Mentor
Joe-Bouza
I created a data shortcut of the corridor; multiple baselines, no offset assemblies. The DataShortcut shows in prospector. Dref dialog open shows all the baselines but never comes in. No error message?
Joe Bouza
RobertEVs
I had had this happen with alignments, surfaces etc. My go-to test is a new dwg then try and dref into that. 100% of the time it would always work with the new dwg. Don't know that this can help you in your current dwg but at least you can know if that is the offender.
Also, what if instead you promote it and see if it comes in that way. How many times over the years of using Civil 3D have I had a "Crrrrraaaap!" moment with something not working as it should
Joe-Bouza
these are the event viewer. subassemblies and attachment and targets are correct. the -1, +1 has me concerned. these are offset alignment profiles that are targets. all the sections look correct. can these errors be stalling the Drefing?
Joe Bouza
Joe-Bouza
i get this trying to Dref the corridor. What does that mean? the Dref operation create "Automatically" the baseline geometry.
Joe Bouza
Joe-Bouza
"Crrrrraaaap!" moment with something not working as it should...
too many to count. lol. First time trying to eliminate some 2d drafting.
I tried the blank drawing no go. How do I promote it if it doesn't come in?
Joe Bouza
