Civil 3D Forum
Drawing Units do not match coordinate system
9 REPLIES 9
Message 1 of 10
athompson469V3
426 Views, 9 Replies
I am using Civil 3D 2023 Imperial. After assigning a coordinate system (IN83-EF), I noticed that my drawing units does not match the scale of the geolocation map. For example, a street I know is 20' wide will measure at 1.667' wide. Somehow, the units are off by a factor of 12. I have attached a picture to show this. Any clues as to how to fix this issue?
9 REPLIES 9
Message 2 of 10
samir.rezk
in reply to: athompson469V3
@athompson469V3
Try the following:
  1. on the command line type: MAPCSASSIGNNONE (to effectively remove any coordinate system in the drawing)
  2. Then go back the Drawing Settings, assign the coordinate system again, and check the box to set AutoCAD Variable to match.
Hope this helps,
Samir Rezk
Technical Support Specialist
Message 3 of 10
rl_jackson
If you units are off by a factor of 12 check to see if UNITS are set to Architectural or if you Dimension Units are set to Architectural.
Rick Jackson
Survey CAD Technician VI
Message 4 of 10
athompson469V3
in reply to: rl_jackson
Both UNITS and Dimension Units are set to Architectural.
Message 5 of 10
athompson469V3
in reply to: samir.rezk
I tried this solution, and it did not help.
Message 6 of 10
rl_jackson
Set both units and dimension units to Decimal/Feet
Rick Jackson
Message 7 of 10
Pointdump
Hi Andrew,
Welcome to the Autodesk Forums.
For fastest diagnosis, please post your drawing.
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2024
Message 8 of 10
athompson469V3
in reply to: Pointdump
Dave, the field contains sensitive information such as addresses and geo spatial data. I cannot post the file.
Message 9 of 10
@athompson469V3
Following @rl_jackson 's advice should fix the issue. Civil 3D does not work with Architectural units.
Allen Jessup
CAD Manager - Designer
Message 10 of 10
Pointdump
Andrew,
Delete everything in your drawing except the dimension linework shown in your screen shot. Also delete the Layouts. Then post your drawing.
Dave
Dave Stoll
Las Vegas, Nevada
Rail Community
