Drawing lines on consecutive point numbers with exclusion
jeff.wangD95HG
jeff.wangD95HG
I want to draw a line to let's say from point 1 to 100. However, I want to exclude a couple points in between that are in different layers.  let's say point 50, 45, 49, 96. 20,21, 89 Typing in the exclusion clause seems a bit tedious to do unless I am missing something.
I started with the line command followed by the point number command and inputted "1-100" I noticed it draws in the undesired points as expected. Then I selected the points I want to exclude and deleted them and I ran the workflow again. I noticed it works just fine with the skipped number and got pretty close to my desired results.
I am wondering if there is some sort of a workflow or trick that allows me to hide the points I want to exclude instead of deleting them for the purpose of drawing line through consecutive points
Pointdump
Hi Jeff,
The way you're doing it is probably the easiest. Only other way I can think of is:
1-19,22-44,46-48,51-88,90-100
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2024
