Drawing has been saved by a newer version....uh, no it hasn't
mcoxinterfluve
Observer Observer
mcoxinterfluve
Observer
Observer
I am currently using Civil3D 2018.
I created a drawing in 2018, but now when I try to re-open it, I get a message that says it has been saved in a newer version, and all my objects are proxy objects.  What would be causing this?  How can it be fixed?
rl_jackson
Do you have more than one version of C3D on you PC, if so verify that you are using the 2018 version.
Rick Jackson
Survey CAD Technician VI
mcoxinterfluve
Observer
Observer
Thanks. No, only 1 version installed. 2018.
user181
Are you using Civil 3D as Autocad instead of civil 3D?
mcoxinterfluve
Observer
Observer
No. Although I do have Civil3D as AutoCAD installed (I do not really use
it).There is a chance that Civil3D as AutoCAD was accidentally used to open
the drawing at some point. Would this cause a problem?
user181
If its the same version it wouldn't cause any problems.
mcoxinterfluve
Observer
Observer
Error fixed. There was a corrupted alignment not recognized. I used erase
all objects identified as "ACAD_PROXY_ENTITY" using qselect, and was able
to open the drawing.
