Hi friends, for the life of me I can not figure out how to draw an arced line using a start point, radius point and angle. I have created an radius point 90° off a line, select the command, pick the end of the line, pick the radius point, enter the delta angle. I then select inquiry, line and arc information, click the curve I just created and it gives me the wrong arc length every time.
I can however select "create point by angle and distance", go through the same process. Click end of line, click radius point, enter angle and distance, give the point a description. Then use the command "draw curve by start/end/radius using the end of the line and the new point I just created and the arc length comes out fine. What gives here???
