Distance between Profiles
LarryS23
LarryS23
How do you find the distance between profile elevations at a given station? Say I want to have a distance of 0.6" from my proposed surface to my existing surface. Is there a quick and easy way to mark on a profile view the stations that this occurs at?
I have originally just been using a station elevation of the profile view and sort of tracing the profiles until I reach the desired difference.
MMcCall402
You could show the vertical distance between the two with a profile view data band.  The band can show the property of "Profile1 elevation minus Profile2 elevation"
Mark Mccall
CAD Mangler
VHB - Engineering, Inc.
LarryS23
Oh I see. The issue is that I want the elevations of the feature line (existing ground) I projected into the profile view displayed
Jeew-m
Create a copy of the proposed profile. Lower it by 0.6".
Then using profile view labels mark all the intersection points with existing ground.
Jeewana Meegahage
Design Engineer
Autodesk Civil 3D Tutorials
Facebook | YouTube | LinkedIn
KirkWM
If you happened to want to convert a feature line to a profile, you can do this using Dynamo and the Civil3DToolKit package. Check out the Dynamo forum for more: https://forum.dynamobim.com/c/civil3d/17
